Memory for the displayed object could not be allocated which may be due to the system running low on memory. This will result in incorrect operation of the Identity Management feature.
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory.
Error
Memory allocation failed when trying to allocate a %obj% structure of size %size%.
| Name | Type |
| obj | String |
| size | uInt32 |
